C2G 1m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BPSWS00 Mfr#: 83386
Length: 1m
Colour: Blue
£4.04 ex VAT
£4.84 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transfer for server applications, cloud computing, and HD video streaming.
  • Durable design
    Constructed with a PVC jacket and 24 American Wire Gauge (AWG) copper wires, this patch cable is built for durability and reliable connectivity. The gold-plated RJ-45 connectors provide optimal signal clarity and shielding against interference, making it an ideal choice for both home and office environments.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable offers a versatile solution for connecting to network components. Whether you're setting up a new network or upgrading an existing one, the male RJ-45 connectors on both ends ensure a secure and straightforward connection.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
24
Plated Connector
Gold
Length
1 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 1m
Colour: Blue
Brand: C2G
