C2G 3m Cat6 550 MHz Snagless Patch Cable - Grey
Quicklinx: 6BPJWS00 Mfr#: 83369
Length: 3m
Colour: Grey
£4.17 ex VAT
£5.00 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable is designed with a PVC jacket and gold-plated connectors to ensure durable and reliable connectivity for all networking needs. With its T568B wiring scheme and UTP technology, this cable provides a high-quality connection that minimizes interference, making it ideal for both home and office environments.
  • Enhanced performance
    Tested to support frequencies up to 550 MHz, this patch cable is perfect for supporting high-speed data transfer and high-bandwidth applications. The American Wire Gauge (AWG) of 24 ensures optimal performance and minimal signal loss, enabling faster and more stable network connections.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends, this network patch cable is compatible with a wide range of devices and networks. Whether connecting PCs, servers, printers, or switches, its universal design ensures seamless integration with existing network infrastructure.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
3 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Grey
Brand: C2G
