The Active High-Speed HDMI cable is the perfect solution for extending HDMI signals in classrooms, conference rooms, boardrooms, and other commercial environments requiring a reliable long-distance connection up to 100 feet (30 metres). The Active HDMI cable features a built-in signal booster that supports HDMI A/V connections at longer distances than non-active cables, allowing you to connect your Blu-Ray player, Laptop, Chromebook or other HDMI device to your HDTV, projector or HDMI-capable display up to 30 metres apart with no signal loss. This cable does not require an external power adapter and supports 1080p resolution at 60 Hz, 3D video, Deep Colour and detailed image display. Additionally, EDID and HDCP are supported for compatibility with HDMI source devices, displays, and content. Combine this active HDMI cable with wall plates for a clean, professional connectivity solution that can be used with projectors in classrooms, conference rooms, or training rooms.
 - C2G 30m Active High Speed HDMI Cable In-Wall, CL3-Rated - HDMI cable - 30 m
- Cable
 - HDMI cable
- Technology
 - Double shielded
- American Wire Gauge (AWG)
 - 28
- Length
 - 30 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - CL3 rated jacket, HDMI CEC support (Consumer Electronics Control), in wall mounting, HDCP compliant, active converter
 - 3-year warranty
- Cable Type
 - HDMI cable
- Technology
 - Double shielded
 - 28
- Jacket Material
 - PVC
- Shielding Material
 - Aluminium foil with aluminium-magnesium braid
- Length
 - 30 m
- Plated Connector
 - Gold
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - EDID compatible
 - Limited warranty - 3 years
