C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black
Quicklinx: 9MRYWS00 Mfr#: 84335
Select:
  • 2m
This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    This 2m Mini DisplayPort to Single Link DVI-D Adapter Cable offers a direct, clutter-free connection to devices, eliminating the need for additional adapters or cables. Its male Mini DisplayPort and male DVI connectors ensure a stable link between your PC and display.
  • High-quality display
    Designed to support high-resolution video, this cable facilitates the transmission of digital video signals from a Mini DisplayPort source to a DVI display. It's perfect for presentations, streaming, or expanding your workstation's visual experience.
C2G 2m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M - Mini DP to DVI - Black - DisplayPort cable - 2 m
DisplayPort cable - single link
Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
TMDS Links
Single link
Length
2 m
Connector
18+1 pin digital DVI (Single-Link) - male
