C2G 2m DisplayPort Male to VGA Male Adapter Cable - Black
Quicklinx: 9MRVWS00 Mfr#: 84332
Length: 2m
Select:
£34.46 ex VAT
£41.35 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a VGA input. This cable carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    The C2G 2m DisplayPort to VGA Adapter Cable offers a seamless link between DisplayPort-equipped PC and VGA-enabled monitors or projectors, ensuring a hassle-free connection without the need for additional adapters or software.
  • High-quality construction
    Crafted with precision, this adapter cable features a durable black casing that not only provides a sleek look but also enhances its longevity, making it a reliable choice for both home and office environments.
C2G 2m DisplayPort to VGA Adapter Cable - DP to VGA - Black - DisplayPort cable - 2 m
DisplayPort cable
Length
2 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
DisplayPort cable
Length
2 m
Connector
20 pin DisplayPort - male
Length: 2m
Brand: C2G
