C2G 20m LC-LC 62.5/125 OM1 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Orange
Quicklinx: 9C98WS00 Mfr#: 85466
With LC to LC termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
  • Reliable connectivity
    The LC-LC 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable ensures consistent and dependable data transmission, thanks to its duplex multimode technology and core/cladding diameter of 62.5 / 125 micron. This makes it an ideal choice for networks that require high reliability.
  • Enhanced safety
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this fiber optic cable minimizes the amount of toxic and corrosive gas emitted during combustion. This makes it safer for use in densely populated environments, ensuring peace of mind for both installers and users.
  • Broad compatibility
    Designed to meet the needs of a wide range of network configurations, this cable is compatible with PC systems and adheres to TIA/EIA-455-171A standards. Its LC multimode connectors offer easy integration into existing setups, making it a versatile solution for various applications.
C2G LC-LC 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable (LSZH) - patch cable - 20 m - orange
Patch cable - OM1
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free
Length
20 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Orange
Network Cable Type
Patch cable - OM1
Duplex fibre optic
Multimode
Jacket Material
Fibre Qty
2
62.5 / 125 micron
Halogen-free
Length
20 m
Orange
Connector
TIA/EIA-455-171A
-20 °C
70 °C
