C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Cable - White
Quicklinx: 9MSQWS00 Mfr#: 84314
Colours:
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirements of high performance applications.
  • Resolution Support
    1080p
  • Cable Colour
    White
C2G 20cm Mini DisplayPort to HDMI Adapter - Thunderbolt to HDMI Converter M/F - White - DisplayPort cable - 15 cm
DisplayPort cable
Length
15 cm
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - female
White
DisplayPort cable
Length
15 cm
White
Connector
19 pin HDMI Type A - female
