Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With ST to ST termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
High-quality connectivity
The ST-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable is designed with a core and cladding diameter of 9 / 125 micron, ensuring high-quality, reliable connectivity for critical network applications. -
Durable and safe
Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion. It's built to withstand temperatures ranging from -20°C to 70°C, making it both durable and safe for a wide range of environments. -
Universal compatibility
With male ST single-mode connectors on both ends and compliance with TIA/EIA-455-171A standards, this cable offers universal compatibility, making it a versatile choice for connecting various PC network components.
- C2G ST-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - network cable - 1 m - yellow
- Network cable - OS1
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Singlemode
- Halogen-free
- Length
- 1 m
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- 2 x ST single-mode - male
- Connector (Second End)
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Singlemode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 9 / 125 micron
- Halogen-free
- Length
- 1 m
- Yellow
- Connector
- TIA/EIA-455-171A
- -20 °C
- 70 °C
