This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Seamless connectivity
Designed to bridge the gap between your Mini DisplayPort and DVI-D devices, this 1m Mini DisplayPort to Single Link DVI-D Adapter Cable offers a male Mini DisplayPort connector on one end and a male 18+1 pin digital DVI (Single-Link) connector on the other, ensuring a seamless connection between your PC and display. -
High-quality construction
Crafted with care, this black adapter cable is built to transmit your video signals without interference or loss of quality, making it an ideal solution for presentations, multimedia applications, and gaming.
- C2G 1m Mini DisplayPort to Single Link DVI-D Adapter Cable M/M - Mini DP to DVI - Black - DisplayPort cable - 1 m
- DisplayPort cable - single link
- Length
- 1 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - male
- Black
- Limited lifetime warranty
- DisplayPort cable
- TMDS Links
- Single link
- Length
- 1 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
