C2G 1m DisplayPort Male to VGA Male Adapter Cable - Black
Quicklinx: 9MRTWS00 Mfr#: 84331
Length: 1m
Select:
£22.89 ex VAT
£27.46 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a VGA input. This cable carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    The 1m DisplayPort to VGA Adapter Cable offers a direct and reliable connection from DisplayPort-equipped devices to VGA monitors or projectors. This ensures a seamless bridge for your video content, making it ideal for presentations, office use, or home entertainment setups.
  • High-quality construction
    Crafted with durability in mind, the cable features robust male connectors on both ends: a 20-pin DisplayPort and a 15-pin HD D-Sub (HD-15), designed to deliver a stable and secure connection while preventing signal loss or interference.
C2G 1m DisplayPort to VGA Adapter Cable - DP to VGA - Black - DisplayPort cable - 1 m
DisplayPort cable
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
DisplayPort cable
Length
1 m
Connector
20 pin DisplayPort - male
Length: 1m
Brand: C2G
