C2G 1m Cat5E 350 MHz Snagless Patch Cable - White
Quicklinx: 6BMYWS00 Mfr#: 83261
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance for both home and office networks.
  • Durable design
    Featuring a robust PVC jacket material, this network patch cable is designed for longevity and durability. Its construction protects against physical strain, external interference, and environmental hazards, ensuring a stable connection through continuous usage.
  • Optimized performance
    With a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for various networking requirements. Its American Wire Gauge (AWG) of 24 and the T568B wiring scheme enhance signal clarity and reduce crosstalk, ensuring high-speed data transmission without compromise.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
White
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
