C2G 2m LC/LC OM4 LSZH Fibre Patch - Violet
Quicklinx: FBGJWS00 Mfr#: 81750
Length: 2m
Colour: Purple
£17.67 ex VAT
£21.20 inc VAT
This OM4 Duplex Multimode fibre optic cable is ideal for connecting 40GBase-SR4 and 100GBase-SR10, SFP+ and QSFP+ transceivers for 40 and 100 gigabit network connections. This cable provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 40 or 100 gigabit Ethernet applications in a data centre or wiring closet.
  • Enhanced connectivity
    The 2 m LC/LC OM4 LSZH Fibre Patch Cable ensures superior connection quality and reliability for high-speed data transmission, featuring a duplex design that supports simultaneous two-way data transfer.
  • Safety first
    Crafted with Low Smoke Zero Halogen (LSZH) jacket material, this patch cable minimizes the amount of toxic and corrosive gas emitted during combustion, making it a safer choice for enclosed spaces.
  • High-quality performance
    With a core and cladding diameter of 50 / 125 micron, this fiber optic cable is designed for multimode use, ensuring high-speed data transmission over longer distances without signal loss.
C2G 2m LC/LC OM4 LSZH Fibre Patch - Purple - patch cable - 2 m - purple
Patch cable - OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
2 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Purple
Network Cable Type
Patch cable - OM4
Duplex fibre optic
Multimode
Jacket Material
Fibre Qty
2
50 / 125 micron
Length
2 m
50 g
Purple
Connector
Length: 2m
Colour: Purple
Brand: C2G
