C2G 15m Cat5E 350 MHz Snagless Patch Cable - Blue
Quicklinx: 6BLXWS00 Mfr#: 83168
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and enhanced performance for your networking needs. The use of T568B wiring scheme and the presence of eight wires per cable facilitate efficient data transmission.
  • Durable design
    Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built for durability and long-lasting use. The PVC jacket offers protection against wear and tear, while the gold plating on the connectors ensures a secure connection and resistance against corrosion.
  • High-speed performance
    Tested to support frequencies up to 350 MHz, this patch cable is capable of delivering high-speed data transmission. It's ideal for supporting the bandwidth requirements of both current and future network applications, making it a smart choice for any setup.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 15 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
15 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
