C2G 1.8M Premium High Speed HDMI Cable w/Eth
Quicklinx: FBGDWS00 Mfr#: 80982
Length: 1.83m
Hurry, only 1 left in stock!
£10.83 ex VAT
£12.99 inc VAT
These Premium High Speed HDMI Cables have been tested to conform with the Premium HDMI Cable Certification Program for highest performance and ultra-reliability. These cables are ideal for HD Blu-ray and HD DVD video, experiencing resolutions up to 4K60 (3840x2160p), bandwidths up to 18Gbps, HDR for higher contrast ratios and vivid colors, plus 32 uncompressed digital audio channels to provide crystal-clear sound, making them perfect for home theatre applications or digital signage. These cables are designed to exceed the highest measure of HDMI performance and will enhance video experiences with higher resolutions, increased speeds, sharper images and are backward compatible with previous HDMI specifications for existing HDMI devices. They also deliver dual video streams, so that two videos can be viewed simultaneously on a single display. Each length of these cables has been tested to deliver the full 18Gbps bandwidth required by the specifications for Premium High Speed HDMI certification. Note: Your display must support Multi-View in order to take advantage of dual video streams.
C2G 1.8m (6ft) Premium High Speed HDMI Cable with Ethernet - 4K 60Hz - HDMI cable - HDMI / audio - 1.83 m
Cable
Shielded
American Wire Gauge (AWG)
30
Length
1.83 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
SMPTE
4K support
Cable Type
HDMI cable 4K support
Interface Supported
HDMI / audio
Shielded
30
Jacket Material
PVC
Shielding Material
Mylar
SMPTE
Length
1.83 m
Audio Return Channel (ARC), Dolby DTS-HD support, Dolby TrueHD support, 32 audio channels, 2 video streams (Dual View)
Connector
19 pin HDMI Type A - male
RoHS II 2011/65/EU
110 g
Limited warranty - lifetime
Length: 1.83m
Brand: C2G
