The USB-C to A 3.0 Male to Male Cable is the perfect solution for connecting any standard USB-C enabled device, such as a Chromebook, laptop, tablet or smartphone, to a USB-A device, accessory or peripheral up to 6ft away for fast charging and high-speed data transfer. Whether you're desk-based or on-the-road, this one-cable solution ensures that your USB-C equipped device is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music, or data at speeds up to 5 Gbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
High-speed connectivity
Experience rapid data transfer with a 5 Gbps data rate, ensuring efficient sync and charge capabilities for your devices. -
Robust compatibility
Designed to meet various USB standards, including USB, USB 2.0, and USB 3.0, this cable offers versatile connectivity options. -
Durable design
Featuring nickel-plated connectors, this cable is built for longevity, providing a reliable connection between your devices.
- C2G 1.8m (6ft) USB C Cable - USB A 3.0 (3A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to USB Type A - 1.8 m
- USB-C cable
- Sync and charge, 5 Gbps data rate
- Length
- 1.8 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - male
- Rated Current
- 3 A
- USB / USB 2.0 / USB 3.0
- Black
- 3-year warranty
- USB-C cable
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 1.8 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, USB-IF, UL 2725, RoHS 2 (2011/65/EU)
- 3-year warranty
