C2G 0.5m RapidRun[R] VGA (HD15) + 3.5mm Flying Lead (1.5ft)
Quicklinx: DWQNWS00 Mfr#: 87114
RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
RapidRun multi-format represents the most significant upgrade to the RapidRun cabling solution to date. With enhanced engineering that includes individually shielded pairs and an isolated ground for audio lines, this solution meets the rigorous demand for applications in which multiple audio/video devices are run over a single cable.
  • Versatile connectivity
    The C2G RapidRun VGA (HD15) + 3.5mm Flying Lead offers versatile connectivity options with its VGA and audio interface, enabling seamless connection to a wide range of multimedia devices.
  • High-quality construction
    Crafted with high-quality materials, this video/audio cable ensures reliable signal transmission and durability for extended use, making it an ideal choice for both professional and home environments.
C2G RapidRun VGA (HD15) + 3.5mm Flying Lead - video / audio cable - VGA / audio - 50 cm
Cable
Video / audio cable - VGA / audio
Length
50 cm
Connectors
HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
Connectors (Second End)
MUVI connector - male
Cable Type
Video / audio cable
Interface Supported
VGA / audio
Length
50 cm
Connectors
15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
Limited warranty - lifetime
