C2G 0.25M ATX PWR TO PENTIUM 4 POWER ADPTR
GREAT VALUE POWER CABLING FROM CABLES TO GO!
Quicklinx: 63VFWS00 Mfr#: 81862
The Pentium 4 power adapter cable from C2G allows you to upgrade to a Pentium 4 motherboard without buying a power supply. This adapter cable allows you to connect a standard 4-pin Molex power connector to the special onboard 4-pin P4 power connector.
C2G - power cable - 4 pin ATX12V to 4 PIN internal power - 25 cm
Power cable
Length
25 cm
Connector
Power 4 pin ATX12V connector - female
Connector (Second End)
4 PIN internal power - male
Power cable
Length
25 cm
Connector
RoHS
