C2G 2m 16 AWG Universal Power Cord (IEC320C13 to BS 1363)
GREAT VALUE POWER CABLING FROM CABLES TO GO!
Quicklinx: 63RSWS00 Mfr#: 88513
Type: Power
26 In Stock
£5.61 ex VAT
£6.73 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This universal power cord is designed to work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. Plus this heavy-duty 16 AWG cord features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into a standard outlet.
  • Versatile compatibility
    Designed to power a wide range of PCs, this universal power cord seamlessly integrates with most computer systems, ensuring a reliable connection and power supply.
  • Durable design
    Featuring a robust 16 AWG cable, this power cord is built to withstand the rigors of everyday use, providing a dependable power solution for your computing needs.
C2G Universal Power Cord - power cable - BS 1363 to power IEC 60320 C13 - 2 m
Power cable
Molded
Length
2 m
Connector
Power BS 1363 - male
Connector (Second End)
Power IEC 60320 C13
Power cable
American Wire Gauge (AWG)
16
Molded
Length
2 m
Connector
Power IEC 60320 C13
Type: Power
Brand: C2G
