C2G 3m Power Cord Splitter
GREAT VALUE POWER CABLING FROM CABLES TO GO!
Quicklinx: DB8ZWS00 Mfr#: 80628
Replace your overused or misplaced power cable, or just manage your power more efficiently. This handy cable features a UK plug which splits to two female C13 shroud. Simply plug the power cord's male prong into a standard power outlet, and you're ready to power multiple electronic devices. Saves space by eliminating extra cords, and keeps your surge strip and UPS outlets from being blocked by bulky AC transformers. Ideal for use in compact workplaces or home offices where there is limited space for electronic equipment. Plus this heavy duty 17 AWG cord features a fully moulded design for maximum durability and long life. Compatible for digital signage, power transformers, computers, monitors, scanners, printers and other devices that use a 3-pin male shroud (C13), often called a Kettle Lead power connector.
  • Product Use
    Power cord for powering multiple devices with one outlet
  • Warranty Details
    This product carries a lifetime warranty
  • Connector Information
    Often referred to as a Kettle Lead power connector
C2G Power Cord Splitter - power splitter - BS 1363 to power IEC 60320 C13 - 3 m
Power splitter
Molded
Length
3 m
United Kingdom
Connector
Power BS 1363 - male
Connector (Second End)
2 x power IEC 60320 C13
Rated Voltage
AC 250 V
Power splitter
American Wire Gauge (AWG)
17
Rated Voltage
AC 250 V
Molded
Length
3 m
United Kingdom
Connector
