C2G .5m Cat5E 350 MHz Crossover Patch Cable - Yellow
Quicklinx: 6BP5WS00 Mfr#: 83348
With a C2G Enhanced Cat5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a peer-to-peer networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable by C2G is designed with high-quality materials, featuring a PVC jacket and gold-plated connectors to ensure durable and reliable connectivity for networking projects.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this crossover cable supports high-speed data transmission. The American Wire Gauge (AWG) of 24 and the use of UTP technology contribute to its superior performance in various networking environments.
  • Universal compatibility
    Equipped with male RJ-45 connectors on both ends, this cable is compatible with PCs and a wide range of network equipment, making it a versatile choice for setting up or extending your network infrastructure.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 50 cm - yellow
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
50 cm
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
