Buffalo Wireless 11ac 1750 Gigabit Dual Band Router with Parental Control
Quicklinx: 9D48WS00 Mfr#: WZR-1750DHP-EU
  • IEEE 802.11n
  • Windows 8 (32/64 bits)
Buffalo's new AirStation Dual Band 11ac Wireless Gigabit router (WZR-1750DHP-EU) brings a new and versatile dual band solution with blazing fast transfer speeds and beamforming technology. The WZR-1750DHP-EU is primed and ready-to-go with transfer speeds of up to 1.3GBps in the 5GHz spectrum and 450Mbps on the 2.4GHz bandwidth! The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new AirStation's simultaneous fast transfer speeds in the 2.4GHz bandwidth.
Buffalo's new AirStation uses beamforming and Multi-user MIMO technologies to remarkably improve your wireless connection. MU-MIMO harnesses the WZR-1750DHP's antennas and beamforming recognizes the devices using wireless and focuses the signal directly to them. And once focused, your wireless signal will have better ability to reach around corners and through walls, helping to eliminate or reduce previous performance obstacles.
In addition to all of this, the AirStation Dual Band 11ac Wireless Gigabit router also offers Norton ConnectSafe web filtering and parental control by Symantec. Upgrade your existing wireless connection to provide greater coverage, beamforming, blazing fast transfer speeds - all whilst protecting your network and your family, Buffalo's (WZR-1750DHP-EU) is the next generation of wireless connectivity.
  • Make your home network extreme
    AirStation Extreme offers an experience enhanced coverage, get high speed gigabit wired connections, connect a printer to the network, add shared storage, stream your favorite HD multimedia, game lag-free and let your family surf the web worry free with Norton ConnectSafe web filtering and parental control by Symantec.
  • Dual Band
    Offering simultaneous wireless operation, AirStation Extreme AC 1750 is perfect for streaming HD movies, music and emailing from multiple devices at the same time.
  • Gigabit Ethernet
    Maximize your wireless network speed with gigabit Ethernet connections that keep your data moving at lightning speed.
  • Beamforming technology
    Beamforming technology optimizes signal energy for enhanced operation with devices that also support the technology. Beamforming creates a more direct wireless signal as it specifically targets supported connected devices, such as the latest MacBook Air, the Samsung Galaxy S4 and the HTC One M7, boosting performance and range even more to deliver a reliable, high speed wireless connection for bandwidth intensive activities.
  • Easy Setup
    AirStation Extreme AC 1750 Gigabit Dual Band Wireless Router features an easy to use, step by step wizard that guides you through configuration from start to finish. Within moments of opening the box, you'll have a secure wireless home network.
  • Wireless bridge
    Configure two or more AirStation Extreme AC 1750 devices to act as a standalone wireless bridge. Create a permanent, high-speed wireless link capable of high speeds and wirelessly extend the range of your network.
  • QoS
    Automatically prioritize your media and entertainment traffic for uninterrupted streaming and lag-free gaming. Best in class features and support for multiple video, audio, gaming, voice and data services provides unharnessed potential for streaming and entertainment possibilities.
  • Extreme range
    HighPower Technology offers optimized antennas and integrated power amplifiers to notably boost signal strength for outstanding range and coverage.
  • Web filtering and parental control
    Powered by Norton, this added level of security easily filters unsafe and restricted content for worry free web surfing the whole family can enjoy.
  • Wireless security
    AirStation Extreme AC 1750 offers the best security standards available, featuring multi-level wireless encryption options to prevent unauthorized access and protect your important data.
BUFFALO AirStation WZR-1750DHP - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), print server, MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
3.4 cm x 18.3 cm x 21.2 cm
580 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Line Properties
Line Coding Format
CCK, OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
18.2 Watt
Software Included
Norton ConnectSafe
3.4 cm
18.3 cm
21.2 cm
580 g
Limited warranty - 3 years
20 - 80% (non-condensing)
9D48 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
