BT4000 Advanced Nuisance Call Blocker - Single
Quicklinx: 8TC0WS00 Mfr#: 069264
Select:
  • Single
BT4000 Big Button Nuisance Call Blocker
An easy to use big button phone that blocks calls from specific numbers or call types.
Featuring
  • Works with all landline providers
  • Large 1.8" screen with amber backlight
  • Easy to use big buttons
  • Hearing aid compatible with amplify button to boost volume
  • Block up to 10 numbers1
  • Block by call type1
  • Base and treble control on incoming speech
  • Save up to 100 contacts
  • Do Not Disturb mode switches ringer off
  • Redial any of the last 30 calls
  • Handsfree speaker
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Struggling to enter numbers accurately, read the screen or hear callers?
This is the ideal phone for anyone with sight, hearing or dexterity challenges. The big buttons and large screen with amber backlight will ease the frustration of entering numbers incorrectly or misreading messages. It’s hearing aid compatible and you can even boost the volume of your caller’s voice to make sure you can hear them clearly.
Fed up with nuisance calls?
You can choose to block specific call types, like international and withheld numbers which account for a lot of unwanted sales calls. You can also block up to 10 specific numbers you don’t want calling you.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker.
Need some peace and quiet?
The Do Not Disturb feature is great for when you need some quiet time, just turn on and your phone won’t ring or light up. You’ll receive calls silently with minimal notification.
  • Block Nuisance Calls
    With the BT4000 Big Button you can choose the type of calls you want to block. For example international and withheld numbers can be blocked, which account for a large proportion of unwanted sales calls. Alternatively if there are specific numbers you want to block, you can block up to 10 numbers from getting through.
  • Big Button
    The BT4000 Big Button is the perfect phone for an elderly customer or sight, hearing or dexterity impaired. The large buttons make dialing easy and accurate and the 1.8" full graphic display ensures clarity when reading the screen.
  • Hearing Aid friendly
    The BT4000 Big Button is hearing aid compatible, thanks to the built-in inductive coupler. This allows you to clearly and comfortably hear telephone conversations through your hearing aid.
  • Full of features that are simple to use
    Do Not Disturb - for those times when you just want some peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
  • All your numbers at your fingertips
    With the BT4000 Big Button you can save up to 100 contacts, letting you keep track of all your favorite people. All these contacts are automatically copied to all of your handsets, ensuring you always have the numbers you need, and saving you time entering them more than once.
  • Stylish phone
    The modern stylish design makes this phone a great addition to any room, whilst only taking up minimal space. 1.8" full-graphical display provides a more quality look and feel. The excellent amber backlight makes it clear and easy to read.
  • Even better for the environment
    Eco credentials come as standard with this BT Phone and it's good to know the packaging it comes in is recyclable and made from FSC certified material. The BT4000 Big Button uses a low energy power supply so is kind to the environment as well as your wallet.
Satin Silver/Black
Calls List
50 numbers
Redial List
30 numbers
Directory
100 name & number
Copy between handsets
GAP compatible
Max number of handsets
5
Internal calls
Music on hold
No
Indoor range
50m
Outdoor range
300m
Backlit
Handsfree
Headset socket
Inductive coupler
Earpiece volume control
Handsfree volume control
Wall mount
No
1 Year Warranty
Resources
The following resources are available for the BT4000 Advanced Nuisance Call Blocker - Single
