BT Everyday Phone without Answer Machine - One Handset
Quicklinx: D9R8WS00 Mfr#: 090661
Type: Cordless phone
Handsets Included: 1
Answer Machine: No
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
42 In Stock
£14.99 ex VAT
£17.98 inc VAT
Everyday Phone
with call blocking
[H4] Sub Section Title
Avoid nuisance and unwanted calls. Block up to 20 numbers you don’t want to take calls from.
Features:
  • Works with all landline providers
  • 1.5 inch amber screen
  • Block up to 20 numbers1
  • Do Not Disturb mode
  • Save up to 50 contacts
  • See who’s calling before you pick up1
  • Redial any of the last 20 calls
  • Adjustable incoming speech volume
1 You need to have a Caller Display service from your network provider to see who’s calling and for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
Call Blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. You can block specific call types, like international and withheld numbers, enter the calls list and select a number that’s called you to block and also store up to 20 specific numbers you don’t want calling you.
Want some peace and quiet?
The Do Not Disturb feature is great for when you need some quiet time, just turn on and your calls will still get through and be added to the calls list but your handset won’t ring.
Want to see who’s calling before you pick up?1
If you subscribe to a Caller Display service, you’ll be able to see your caller’s number on the handset display (provided it’s not withheld) before you answer the call. If your caller’s name is stored in your contacts list and it matches the number calling, you’ll see the caller’s name displayed instead.
1 You need to have a Caller Display service from your network provider to see who’s calling. Charges may apply.
Packed with great features
An easy to set up phone with excellent sound quality. You can save up to 50 contacts and redial any of the last 20 calls you made.
  • Nuisance Call blocking features
    The Everyday phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to.
  • Do Not Disturb
    For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book.
BT Everyday - cordless phone with caller ID
Cordless phone with caller ID
Total Number of Wireless Handsets
1
Cordless Phone Standard
DECT\GAP
Call Services
Call Waiting, Call Transfer
Display
LCD display - monochrome - Yes
Cordless phone
1
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
5
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Volume Control
Ring Tones
5
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom
Phone Memory
Phone Directory Capacity
50 names & numbers
Caller ID Memory
20 names & numbers
Display
Display Location
Handset
Diagonal Size
1.6"
Backlit
Placing / Mounting
Table-top
AAA type
500 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 600 min
Standby Time
Up to 100 h
Dimensions & Weight (Base)
10.4 cm
11.6 cm
4.2 cm
86 g
Dimensions & Weight (Handset)
5.1 cm
3.2 cm
16.6 cm
94 g
Resources
The following resources are available for the BT Everyday Phone without Answer Machine - One Handset
Answer Machine: No
Mounting: Table-top
Big Button: No
Brand: BT
