Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Push faster, stronger wi-fi to every corner of your home. Using the latest AX6600 Tri-band Wi-Fi technology to create a complete Wi-Fi network.
- This disc only works to extend your existing Whole Home Wi-Fi 6 - Three Disc Pack (cannot be used standalone)
- Works with all broadband providers
Complete control
See who's online and connected to your Wi-Fi, pause the internet for everyone or by individual devices, set schedules for the kids' bedtimes and create a separate Wi-Fi network for guests. -
Super smart
Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
- BT Mini Whole Home Wi-Fi 6 - Add-on - radio access point - Wi-Fi 6
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Performance
- Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 4.8 Gbps
- Power
- AC 230 V (50 Hz)
- 18.2 cm x 7.1 cm x 18.2 cm
- 468 g
- 18.2 cm
- 7.1 cm
- 18.2 cm
- 468 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- Performance
- Roaming function, Wi-Fi Protected Setup (WPS), reset button, band steering, Backhaul Technology, 2x2 MIMO technology, 4x4 MIMO technology
- Encryption Algorithm
- AES, WPA, WPA2, WPA3
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
Aerial
- Antenna
- Internal
- 2 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Power Device
- External power adapter
- Voltage Required
- AC 230 V (50 Hz)
- 11.4 Watt
- Shipping Width
- 8.15 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 26 cm
- 0 °C
- 45 °C
- 10 - 90%
