BT Infinity Home Hub 3 & Welcome Pack
At the heart of BT Total Broadband is the BT Home Hub.
Our new BT Home Hub can connect many devices around your home - with or without wires. It features smart wireless technology to ensure a strong connection, plus built-in security and intelligent power management.
- Sleek new design
- Simple set-up
- Smart wireless - ensuring a strong connection
- Wireless-N technology
- Intelligent power management - automatically adjusting power usage
- WPS enabled
- Simple re-start switch
- Built-in fireweall
- WPA2 as standard (Wi-fi protected access)
- Infinity ready
Hub 3 does not support DECT and is not compatible with BT hub phones.
BT Home Hub only works with a BT Broadband service. It cannot be used with another ISP.
Please note, the BT Home Hub 3 does not support the Broadband Talk service. There is no socket to directly connect either a Hub Phone or standard telephone to this hub so you will not be able to continue using your Broadband Talk service. However you can still connect telephones to your standard telephone sockets and use your regular telephone line.
