Brother MFC-8950DWT Mono Laser Multifunction Printer
Quicklinx: 8CQWWS00 Mfr#: MFC8950DWTU1
Work more efficiently with the MFC-8950DWT multifunction printer.
This robust, machine – a heavyweight performer in any demanding office – offers a high speed output at up to 40ppm, up to 12,000 page super high-yield toner cartridges and an intuitive touchscreen. Automatic duplex printing – plus duplex copy, scan and fax – and a standard paper tray capacity of 1,050 sheets means you'll spend less time waiting for your printouts and also won't have to refill so often.
The MFC-8950DWT also has a range of energy saving functions, including toner save and deep sleep modes, which ensure your business enjoys both reduced costs and a smaller carbon footprint.
Brother MFC-8950DWT - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
5000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
1200 x 1200 dpi
Display
5"
Original Size
147.3 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
1050 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
AC 230 V (50/60Hz)
49.1 cm x 41.5 cm x 60.7 cm
20.8 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
5000 pages
Display Diagonal Size
5"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB 128 MB
Max Supported Memory
384 MB 384 MB
Copying
Max Copying Speed
Up to 40 ppm
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Sort
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, BR-Script 3
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
32 station(s)
Speed Dialing
300 station(s)
Broadcast Transmission
382 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction
Document & Media Handling
Min Original Size
147.3 x 147.3 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
1050 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , 2 x input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 18 spm (A4) - B/W duplex , Copying: up to 40 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP, IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, HTTPS, IPv4, IPv6, FTP, SMTP, DHCP, BOOTP, RARP, NetBIOS
Security Protocols & Features
LDAP, Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, Apple Mac OS X 10.7.x
Software Included
Drivers & Utilities, Brother BR-Admin Professional, Brother BR-Admin Light for Linux & Macintosh
AC 230 V (50/60Hz)
694 Watt
Power Consumption Standby
9.8 Watt
Power Consumption Sleep
6.8 Watt
First Copy Out Time B/W
10.5 sec
Consumables Included
1 x toner cartridge (black) - up to 8000 pages , 1 x drum - up to 30000 pages - Brother DR3300
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
49.1 cm
41.5 cm
60.7 cm
20.8 kg
Shipping Width
76.4 cm
Shipping Depth
56.3 cm
Shipping Height
92.4 cm
Shipping Weight
35.2 kg
Sound Emission
37 dBA (idle) / 59 dBA (operating)
10 °C
32.5 °C
20 - 80% (non-condensing)
8CQW Brother HL5100 Series Drum Unit In Stock £132.91
8CQW Brother TN3330 Toner Cartridge - Black In Stock £57.26
8CQW Brother TN3380 Black Toner Cartridge In Stock £90.22
8CQW Brother TN3390 Toner Cartridge - Black In Stock £101.69
