Brother DCP 8110DN Mono Laser Multifunction Printer
Quicklinx: 8BHRWS00 Mfr#: DCP8110DNZU1
This impressive multifunction machine can help you to hit your important deadlines. It offers high-speed printing and copying up to 36ppm – with the first page out in just 8.5 seconds – and delivers consistently professional documents effortlessly.
This versatile all-in-one also boasts cost- and energy-saving features such as a toner save mode and deep sleep mode, as well as an optional high-yield toner cartridge.
If you need professional results fast, the DCP-8110DN is a high-speed office partner you can rely on.
  • Fast printing and copying
    Quickly produce high-quality black and white output at print and copy speeds up to 38 pages per minute.
  • Automatic two-sided printing
    Print professional two-sided documents, brochures, and booklets using the built-in duplex feature. This feature can help you save money and cut your paper usage by up to 50%.
  • Flexible connectivity
    Print or scan over your Ethernet network or connect locally via its Hi-Speed USB 2.0 interface.
  • Valuable copier features
    Includes time-saving copier features such: standalone copying, ID copy, sorting, reduce/enlarge documents from 25-400%, and N-in-1 copying.
  • Advanced scanning capabilities
    Offers high-quality color scanning and supports a variety of "scan to" functions including: E-mail, file, image, OCR, FTP, and network folder.
  • Flexible paper handling
    The DCP-8110DN features an adjustable, 250-sheet capacity tray for letter or legal-size paper, plus a 50-sheet capacity multi-purpose tray.
  • Cost efficient performance
    A high-yield 8,000-page toner cartridge is available to help lower your operating costs.
  • 35-page capacity auto document feeder
    Use for unattended copying or scanning of multi-page documents.
  • Convenient walk-up printing and scanning
    A USB direct interface is located on the front of the machine for printing files from or scanning files to your USB flash memory drive.
  • Advanced security features
    This monochrome laser multi-function copier provides a wide range of security features including: secure print, secure function lock, enterprise security and more.
Brother DCP-8110DN - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
3500 pages
Max Copying Speed
Up to 36 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 36 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
69.8 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
40.5 cm x 41.5 cm x 42.3 cm
15.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Laser - monochrome
3500 pages
Display
5 lines x 22 characters
AirPrint Enabled
Standard Memory
64 MB 64 MB
Max Supported Memory
320 MB 320 MB
Copying
Max Copying Speed
Up to 36 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 36 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, BR-Script 3
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
69.8 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 69.8 x 116 mm - 216 x 406.4 mm weight: 60 g/m² - 163 g/m² , ADF - 35 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 36 ppm - B/W , Copying: up to 36 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
IPv4, IPv6
Operating System Support
MS Windows XP, Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, Apple Mac OS X 10.7.x
Software Included
Drivers & Utilities, Brother BR-Admin Professional, Brother BR-Admin Light for Linux & Macintosh
615 Watt
Power Consumption Standby
8.1 Watt
Power Consumption Sleep
1.2 Watt
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x drum - up to 30000 pages - Brother DR3300
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
40.5 cm
41.5 cm
42.3 cm
15.6 kg
Shipping Width
53.3 cm
Shipping Depth
51.5 cm
Shipping Height
60.1 cm
Shipping Weight
19.7 kg
8BHR Brother TN3330 Toner Cartridge - Black In Stock £57.26
8BHR Brother TN3380 Black Toner Cartridge In Stock £90.22
