Belkin WeMo Smart Light Bulb Starter Kit Bundle (Screw Type)
Quicklinx: 9XQHWS00 Mfr#: F5Z0489UK
Turn lights on, off or dim individually or as a group -- from anywhere
Create custom schedules and control for your LED lights individually or as a group
Have your smart bulbs turn on a sunset or have them turn off at sunrise
Simulated Occupancy feature turns your lights on and off automatically making it look like you're home - even when you're not.
WeMo Smart LED Bulbs can gradually dim, so you can fall asleep in a more natural way
With the WeMo Lighting Starter Set you've already got everything you need: WeMo works with your existing home Wi-Fi network and mobile Internet (3G / 4G)
Modular system. You can add additional WeMo LED Light Bulbs easily, any time
Intuitive, easy set up and easy to use
Works with the entire family of Belkin WeMo products
Free WeMo App for Android, iOS and Kindle operating systems
Works with IFTTT, connecting you to a whole world of Web apps
WeMo works on multiple smart devices simultaneously
WeMo Smart LED Bulbs have a 23 year life expectancy
Bright, warm light similar to a 60W incandescent bulb
Two-year limited warranty
DEVICE COMPATIBILITY
Android smart devices running Android 4.0 or higher
iOS smart devices running iOS 6 or higher
iPod Touch 3rd Generation and later
iPhone 3GS and later
iPad 2 and later
iPad Mini
SYSTEM REQUIREMENTS
Wi-Fi Router with an internet connection
Either Android 4.0 or higher/ iOS 5 or higher
WiFi 2.4GHz 802.11n
WeMo App (downloadable from App Store, Google Play Store or Amazon App Store)
PRODUCT SPECIFICATIONS
Form Factor : A19
Connector Type : Screw type
Input Power : 230V
Beam Angle : >240°
LED Output Temperature: 3000K
LED Output Brightness : >800 Lumens (60 Watt Incandescent Equivalent)
Dimmable : 50 lumens/watt
Life: 25,000 hours L70
Communications : ZigBee running HA 1.2 supporting "Dimmable Light" clusters. Tested to 50 devices, capable of potentially 500.
Number of Power Outlets: 1
PACKAGE CONTENTS
2 WeMo Smart LED Bulbs
1 WeMo Link
WARRANTY
2 year Limited Warranty
  • Turn your lights On/Off and dim them from anywhere
    The WeMo LED Lighting Starter Set lets you access and control your WeMo Smart LED Bulbs from anywhere, using your existing home Wi-Fi network and mobile Internet. Dim lights, turn them on or off, or create a custom schedule that works for your family. You can also set your lights to turn on automatically at sunset, dim them to watch a movie, or turn them off after you leave home, all from your smart device.
  • Lighting to match your mood
    WeMo Smart LED Bulbs can be dimmed to create the perfect ambiance - right from your smartphone. Dim the dining room lights for perfect restaurant lighting for a special meal, a celebration, or entertaining. The lights can be used at full brightness to help your kids with their homework productivity. Turn the living room lights down a little and curl up with your favorite book, or turn the bedroom lights down to relax. There is also a dim to sleep feature, setting the light to gradually dim until they're completely off. Establish a calming mood to help you fall asleep in a more natural way.
  • Control up to 50 WeMo smart led bulbs
    The WeMo LED Lighting Starter Set includes two WeMo Smart LED Bulbs and WeMo Link. WeMo Link allows you to connect up to 50 WeMo Smart LED Bulbs and control them individually or as a group. Additional WeMo Smart LED Bulbs are sold separately.
  • Look like you're home, even when you're not
    Ideal for vacations and weekend getaways, the simulated occupancy feature controls all of your WeMo connected electronics through a random algorithm to turn things on and off automatically. It will appear as if you're at home, even when you're not. For example, your WeMo LED Light Bulbs can turn on in your bedroom, the radio connected to your WeMo Switch can play music in the living room, or your WeMo LED Light Bulbs can turn on for 45 minutes in your kitchen. From the outside looking in, it'll look like you're at home enjoying a night in.
  • Easy to use, easy to install
    Installation is quick and easy. Simply plug WeMo Link into a central outlet in your home, replace your old light bulb with the WeMo Smart LED Bulb, use any smart device and enjoy. WeMo LED Lighting keeps you connected to your home lighting anywhere you are - over Wi-Fi, 3G, or 4G networks.
Belkin WeMo Starter-Set - wireless lighting set - LED light bulb x 2 - shape: A19 - E27 - 9.5 W - total: 19 W - warm white light - 3000 K
Wireless lighting set
Light Source Type
2 x LED light bulb
Total Wattage
19 W (equivalent 120 W)
Dimmer
Shape
A19
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Beam Angle
240 degree(s)
AC 220 - 240 V
Frequency Required
50 Hz
Total Wattage
Dimmer
Android compatible, iOS compatible, Wi-Fi controlled
Light Source
2 x LED light bulb
Shape
A19
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Luminous Efficacy
50 lm/W
Beam Angle
240 degree(s)
Lifetime
25000 hours
ZigBee technology
Power Requirements
AC 220 - 240 V
Frequency Required
50 Hz
WeMo Link bridge
Warranty
2 years
