Designed for inventors and tinkerers, the WeMo Maker makes it possible to control low-voltage electronics devices using a smartphone or tablet. The WeMo Maker works over your home Wi-Fi network and lets you turn your devices on and off, put them on schedules, or connect them to different sensors. An ideal tool for hobbyists who have wiring knowledge and enjoy taking electronics apart, the WeMo Maker can connect to nearly any device controlled with a DC switch. Once connected, the WeMo Maker allows you to monitor a variety of 5v digital sensors.
WeMo Maker works with IFTTT, a service that lets you create powerful connections with one simple statement: IF this, then that. You'll be able to use any data source on the web to act as a WeMo trigger and create customized automation rules and schedules to fit your personal preferences. You can, for example, create a trigger to open the pet door for your dog at sunrise or when you log out of your work email for the day. With WeMo and IFTTT, your imagination is your only limit. Belkin's expanding WeMo ecosystem now includes light bulbs, a motion detector, an energy monitoring switch, and even a Crock-Pot slow cooker. With WeMo Maker, technically expert users will now be able to connect any low voltage device into the WeMo ecoystem. Since the system is modular, you can automate as much or as little of your home as you'd like.
Inventors can add Wi-Fi capability to their toolbox
Designed for inventors and tinkerers, the WeMo Maker makes it possible to control low-voltage electronics devices using a smartphone or tablet. The WeMo Maker works over your home Wi-Fi network and lets you turn your devices on and off, put them on schedules, or connect them to different sensors. -
Wemo maker can be used as a controller, a sensor or a manager
An ideal tool for hobbyists who have wiring knowledge and enjoy taking electronics apart, the WeMo Maker can connect to nearly any device controlled with a DC switch. Once connected, the WeMo Maker allows you to monitor a variety of 5v digital sensors. -
Limitless customization
WeMo Maker works with IFTTT, a service that lets you create powerful connections with one simple statement: IF this, then that. You'll be able to use any data source on the web to act as a WeMo trigger and create customized automation rules and schedules to fit your personal preferences. You can, for example, create a trigger to open the pet door for your dog at sunrise or when you log out of your work email for the day. With WeMo and IFTTT, your imagination is your only limit. -
Expand your wemo ecosystem
- WeMo Maker - central controller - 802.11b/g/n
- Product Type
- Central controller
- Connectivity
- Wireless - 802.11b/g/n
- Supported Host Device OS
- iOS, Android
- Product Type
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Android 4.0 (Ice Cream Sandwich) or later, iOS 6 or later
Internet of Things (IoT)
- Compatible Services
- IFTTT
Aerial
- Form Factor
- External integrated
RAM
- Installed Size
- 32 MB
Flash Memory
- Installed Size
- 16 MB
- Included Accessories
- Power adapter, USB cable
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- 0 °C
- 40 °C
- 0 - 80%
