Control from Anywhere
Remotely control your connected devices on your smartphone.
Compact Design
Fits into sockets without blocking adjacent ones.
Voice Control
Free up your hands with simple voice commands. Works with Alexa, Google Home, and Bixby.
Schedule and Timer
Set a schedule or timer to switch your devices on or off automatically.
Multiple Safety Guarantees
Overheating protection and PC flame retardant material help minimize burning hazards. A sliding safety cover protects children from electric shock.
Hands-free voice control
Connect your smart plug with Amazon Alexa, Google Assistant, and SmartThings, and control connected devices by only using your voice. -
Simple to set up and use with Alexa
Setup is faster than ever before with Alexa. Use your Echo device to set up the plug via voice command. -
Remote access
Control devices connected to the smart plug wherever you have internet using the free Kasa app on your smartphone. -
Scheduling
Set schedules with the Kasa Smart app to automatically turn your smart plug on or off while you're away. -
Easy setup
Download the Kasa Smart app and follow the setup instructions for your plug.
- Kasa Smart KP105 V1 - smart plug - 802.11b/g/n
- Product Type
- Smart plug
- Functions
- Turn electronics on/off
- Internet of Things (IoT) Platform
- Google Home, SmartThings
- Intelligent Assistant
- Alexa, Bixby
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- 2-year warranty
- 5.15 cm x 3.75 cm x 7.25 cm
- Product Type
- Smart plug
- Functions
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- OS Required
- Android 5.0 or later, Apple iOS 10 or later
- Interfaces Details
- Power input
- Child protection, voice control, overheat protection, flame-retardant, up to 13 A
- Platform
- Alexa, Bixby
- Product Material
- Polycarbonate
- Nominal Voltage
- AC 100 - 240 V
- Warranty
- 2-year warranty
- RoHS
- 5.15 cm
- 3.75 cm
- 7.25 cm
- 90 g
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
