Good speed and coverage, with a range that easily covers your small home or apartment. Belkin's Surf routers are aimed at people wanting to surf the web from anywhere in their home, but have been put off by traditional routers' over-complicated installation. Get your secure wireless network up and running in minutes. Just three easy steps, and you're up and running out of the box and onto the Web.
- Belkin F7D1401 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- TCP/IP, PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- Dynamic IP address assignment, NAT support, VPN support, SPI, MIMO technology, QoS, WPS, IPSec passthrough
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n
- Environmental Standards
- ENERGY STAR Qualified
- System Requirements
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 - 10.6
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Static IP routing
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 256-bit WPA, WPA2, WPA-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, Plug and Play
- Status Indicators
- Status
Communications
- DSL modem
- ADSL
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- ENERGY STAR Certified
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities, Self-Healing
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85%
