The Belkin N600 Dual-Band Wi-Fi Range Extender expands your wireless network, while its compact, elegant design complements your home decoration. With high performance speeds of up to 300 Mbps (2.4 GHz) + 300 Mbps (5 GHz) and external antennas for superior range, you'll have strong, reliable Wi-Fi throughout your home. Simple Start makes set up quick and easy on any smartphone, tablet or laptop - just plug the Belkin N600 Dual-Band Wi-Fi Range Extender right into the wall, access simple start and you're ready to go in minutes. Crossband technology increase speeds vs. normal range extenders by switching to the least congested band. Compatible with G and N technology devices, the N600 Dual Band Wi-Fi Router makes home networking a lot easier by keeping all your Wi-Fi devices connected.
- Belkin N600 Dual-Band Plug-In Wi-Fi Range Extender - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- Microsoft Windows XP SP3 or later, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- 2-year warranty
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Status
- Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- OS Required
- Limited warranty - 2 years
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
