Belkin N Wireless Modem Router (BT ADSL)
Customer rating: 5.0* (Write a review)
Quicklinx: 4PR8WS00 Mfr#: F5D8633UK4A
  • IEEE 802.11n (draft)
Connect your wired and wireless desktop computer and notebooks to your Belkin N Wireless Modem Router to share your broadband Internet access. Now you can quickly exchange documents, share resources, and distribute large video and music files throughout your network at a link rate of up to 300Mbps. The advanced security protects both your wireless and wired computers from hackers and intruders. You can add up to 16 computers to your wireless network with additional notebook and desktop adapters. For better wireless performance, use the Belkin N Wireless Modem Router with N Wireless Notebook and Desktop Cards connecting your client computers.
Belkin F5D8633-4 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, AppleTalk, PPTP, UDP/IP, NetBEUI/NetBIOS, L2TP, PPPoE, PPPoA, IPoA, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, dynamic IP address assignment, DHCP support, NAT support, SPI, MAC address filtering, VPN passthrough, MIMO technology, IPSec passthrough
Microsoft Windows 2000 / XP, Apple MacOS X 10.3, Apple MacOS X 10.4, Microsoft Windows Vista
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Max Range Open Space
365 m
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Communications
DSL modem
ADSL
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL - RJ-11
Aerial
Antenna Qty
2
Directivity
Omni-directional
External power adapter
United Kingdom
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
Customer reviews
Write a review for the Belkin N Wireless Modem Router (BT ADSL) here!
Great service again and again
Reviewed by Danny. Review Posted 03/01/2008
firstly i bought myself a new sony vaio laptop and Dabs deliverd the next working day and the product was amasing, and now again i have brought a new Belkin N Wireless Modem Router + Belkin Network USB Hub package along with a few other pieces and once again Dabs deliverd the goods next working day. The modem router is extreamly easy to set up and the WiFi connection quality and range are amasing. as for the Network Usb Hub, it may as well be Plug and Play, jus install the simple drivers and its good to go. they are both so easy to use. an exilent buy. They really provide an exilent service with a great range of products.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Quick setup and excellent performance
Reviewed by James. Review Posted 31/08/2008
Once again Belkin has kicked out an excellent piece of technology, this is now my third Belkin router and the ease of setup and use is just as good as the rest (even with this being a higher spec device). There is total customisability through the routers control panel (you can setup your internet connection, change your WiFi security and even make it solely a wireless access point) which is a feature you can find hard to get in competing devices. Like all other routers over time the box gets rather warm so I suggest you either mount it on a wall or leave it on a desk (but not on a carpeted floor) to avoid an over heating problem. Finally hats off to Dabs for delivering this in just one day and for beating PC Worlds price by £40 (as of August 2008).
  • Overall 5*
  • Ease of use 5*
I love this product
Reviewed by Anonymous Review Posted 16/01/2008
we use 2 laptops at home and sometimes 3 at the same time, and the speed of the net is amazing. i tried a few other brands but belkin is the best. another thing you need to consider, the fact their customer service team is always there to help, fast and efficient.. i am so impressed with their service. totally recommend this product - you won't be facing any problems.
  • Overall 5*
  • Ease of use 5*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
