Enjoy fantastic Internet speeds and whole-home coverage for all your Wi-Fi devices with the AC1750 DB Wi-Fi dual-band AC+ Gigabit router. The AC1750 operates up to 4.3x faster than wireless-N technology at up to 450 Mbps (2.4 GHz) and 1.3 Gbps (5 GHz). The dual band router offers media (5 GHz) and standard (2.4 GHz) bands so you can stream movies or enjoy online games without interruption - even if your family members or roommates are accessing the Internet in the other room on their Wi-Fi devices.
Easy setup via smartphone, tablet, or computer
With simple start feature, installation is easy - just use a smartphone, tablet, or computer to set up your router. -
Stream movies without interruption
IntelliStream QoS automatically prioritizes video and gaming streams, so you can kick back and enjoy uninterrupted streaming for movie nights or gaming marathons. -
High-powered signal provides full coverage
MultiBeam antenna technology minimizes dead spots while optimizing streaming to multiple devices, even if you're on the opposite side of the house. -
USB and Gigabit Ethernet ports
It features two USB connections - one high-speed USB 3.0 port as well as a USB 2.0 port - that allow you to connect an external USB storage device or a USB printer for wireless printing. For an ultra-fast and reliable wired connection, simply plug in to one of the router's four LAN Gigabit Ethernet ports or the WAN Gigabit Ethernet port. -
Backward-compatible with N and G technology
The wireless AC router is backward-compatible with N and G technology, so all your older computers and wireless devices will work with it.
- Belkin F9K1115 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.3 Gbps
- L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- DHCP support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, DLNA Media Server
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.3 Gbps
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- 128-bit WEP, 256-bit WPA
- Status Indicators
- Status, USB, WPS
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- 0 °C
- 40 °C
- 10 - 85%
