Pure Base 600 is truly multi-talented, offering a great deal of functionality and features for an attractive price. This case sets new standards in its performance class with high installation flexibility and effective cooling performance. Smart usability features and whisper-quiet operation enable you to realize almost any system configuration you desire for your ATX or micro ATX PC. It's simply the perfect base to build your system on.
- be quiet! Pure Base 600 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x microphone , 1 x headphones
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Removable dust filter, front dust filter, supports 120 mm radiator in rear, side panel sound-damping foam mats, removable HDD cage, bottom dust filter, supports 120/140/240/280/360 mm radiator in front panel, supports 120/240/360 mm radiator in top, top panel sound-damping foam mats, front panel sound-damping foam mats, manual fan speed control (3 channel)
- Power Device
- No power supply (ATX / PS/2)
- 22 cm x 49.2 cm x 47 cm
- 7.44 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 2
- Product Material
- Steel, ABS plastic
- Black
- Cooling System
- Front: 140 x 140 x 25 mm fan x 1 / 900 rpm / 55.8 cfm / 17.1 dBA / 1 x 120/140 mm fan supported , Rear: 120 x 120 x 25 mm fan x 1 / 1200 rpm / 41.7 cfm / 16.8 dBA / Pure Wing 2 , Top: 140 mm fan mount x 2 / 2 x 140 mm fan or 3 x 120 mm fan supported
- CPU Cooler Max Height
- 165 mm
- Video Card Max Length
- 425 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 2 x 2.5"/3.5" shared
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
- Included Accessories
- Cable ties, screws
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- 22 cm
- 49.2 cm
- 47 cm
- 7.44 kg
- Limited warranty - 3 years
