Be Quiet BG001 Silent Base 800 Orange
Quicklinx: 9Z2CWS00 Mfr#: BG001
  • Max Mainboard Size:ATX
  • CPU Cooler Max Height:160 mm
  • Video Card Max Length:290 mm
  • Form Factor:Tower
  • System Cabinet Features:Vibration-absorbing drive cage, screwless drive bays, side panel dust filter, removable dust filter, vibration damping, front dust filter, CPU cut-out, water cooling holes, cable management system, removable HDD cage, bottom dust filter, airflow channels, side panel with adjustable 3 in 1 air intake
be quiet! Silent Base 800 - tower - ATX
System cabinet
Tower
Orange
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
No power supply
23 cm x 49.5 cm x 54.2 cm
9.31 kg
3-year warranty
Tower
Max Mainboard Size
ATX
Internal Bays Qty
7
Front Accessible Bays Qty
3
Orange
Cooling System
Front: 140 x 140 x 25 mm fan x 2 / intake / 1000 rpm / 61.2 cfm / 18.8 dBA / Pure Wing 2 , Rear: 120 x 120 x 25 mm fan x 1 / exhaust / 1500 rpm / 51.4 cfm / 19.2 dBA / Pure Wing 2 , Top: 120/140 mm fan mount x 2 / exhaust , Bottom: 120/140 mm fan mount x 1 / intake , Side: 120 mm fan mount x 1
160 mm
290 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 3.5"
Expansion Slots
7
2 x USB 3.0 , 2 x USB 2.0 - mini-jack , 1 x headphones , 1 x microphone - mini-jack
Cable ties, HDD rubber slide rail
RoHS
No power supply
23 cm
49.5 cm
54.2 cm
9.31 kg
Limited warranty - 3 years
