Asus VW199TL 19" 1440x900 5ms VGA DVI LED Monitor
Quicklinx: 9TRBWS00 Mfr#: VW199TL
It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • 50000000:1 ASUS smart contrast ratio
  • Ergonomic design for personal visual comfort
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
  • Mercury-free LED-backlit panel
    Corrugated cardboard packaging with at least 80% recycled content. Slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and CO2 emission.
ASUS VW199TL - LED monitor - 19"
LED-backlit LCD monitor - 19"
Power Consumption (On mode)
13.1 W
Panel Type
TN
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
44.4 cm x 21.4 cm x 36.44 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, ISO 13406-2, WHQL, CB, CCC, PSB, EK, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS
3-year warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, sharpness, colour temperature
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
44.4 cm x 21.4 cm x 36.44 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Audio line-in , VGA , DVI-D
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
AC 120/230 V
13.1 W
Power Consumption (Typical)
27 Watt
Power Consumption Stand by / Sleep
0.2 Watt
0.16 Watt
Power Consumption Sleep
0.15 Watt
Dimensions & Weight Details
Without stand - width: 44.4 cm - depth: 29.57 cm - height: 6.46 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
