ASUS ZenScreen Go MB16AP is designed to keep you productive, wherever you are. It's a portable monitor with a hybrid-signal solution, which means that it only needs a single USB connector cable to be fully compatible with almost any laptop. With a super-slim 8 mm profile, and weighing just 850 g, ZenScreen Go MB16AP is also light 15.6-inch companion display.
To enjoy the convenience of a truly portable device with 7,800 mAh battery built-in that supports up to 4 hrs battery life. Support QC3.0 fast battery charging, doubled charging speed in comparison to general adapters. ZenScreen Go MB16AP works with laptops, and mobile devices. To project app or content from your mobile device, simply download and use the DisplayLink app. To check battery status by simply press the hotkey.
ZenScreen Go MB16AP only requires a single USB connection for both power and video transmission from your host device. It features an innovative hybrid-signal solution with native support for USB Type-C (USB-C) connections, and uses an installed driver to support USB Type-A connectors for full compatibility. The reversible, any-way-up USB-C design enables quick, hassle-free connection to any device.
Extend your vision, free your world
ASUS ZenScreen Go MB16AP is designed to keep you productive, wherever you are. It's a portable monitor with a hybrid-signal solution, which means that it only needs a single USB connector cable to be fully compatible with almost any laptop. With a super-slim 8 mm profile, and weighing just 850 g, ZenScreen Go MB16AP is also light 15.6-inch companion display. -
Built to be on the go
To enjoy the convenience of a truly portable device with 7,800 mAh battery built-in that supports up to 4 hrs battery life. Support QC3.0 fast battery charging, doubled charging speed in comparison to general adapters. ZenScreen Go MB16AP works with laptops, and mobile devices. To project app or content from your mobile device, simply download and use the DisplayLink app. To check battery status by simply press the hotkey. -
Hybrid-signal solution: USB Type-A and Type-C support
ZenScreen Go MB16AP only requires a single USB connection for both power and video transmission from your host device. It features an innovative hybrid-signal solution with native support for USB Type-C (USB-C) connections, and uses an installed driver to support USB Type-A connectors for full compatibility. The reversible, any-way-up USB-C design enables quick, hassle-free connection to any device. -
Slim and stylish ultraportable design
ZenScreen MB16AP is ideal for use as a secondary monitor for dual-monitor presentations, and its versatility helps you get things done more efficiently when you're on the go. It barely tips the scales at a lightweight 850 g, and with its ultra-slim 8 mm profile it fits easily in any travel bag. -
Wide viewing angles
ZenScreen Go MB16AP features a Full HD panel that delivers stunning 1920 x 1080 resolution visuals with outstanding color reproduction. It uses IPS technology to give you more flexibility when extending your screen, so you still get superb color and contrast - even from extreme viewing positions.
- ASUS ZenScreen GO MB16AP - LCD monitor - Full HD (1080p) - 16"
- LCD monitor - 16"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/419761
- Energy Class
- Class C
- Power Consumption (On mode)
- 7 W
- Lithium-polymer battery (7800 mAh)
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- 262,000 colours
- Input Connectors
- USB-C
- Dark grey
- 35.97 cm x 0.8 cm x 22.64 cm
- 850 g
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, J-MOSS, UkrSEPRO, RCM, BIS, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class C
- Diagonal Size
- 16"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- 262,000 colours
- Glare, ASUS Splendid Video Preset Mode, ASUS GamePlus, Slim Design, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, auto-rotation, USB 3.0 Quick Charge, Wide Viewing Angle, Super Narrow Bezel Design
- Dark grey
- 850 g
- USB-C
- Included Accessories
- ZenScreen pen, ASUS Smart Case
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A adapter
- 7 W
- Power Consumption SDR (On mode)
- 7 kWh/1000h
- Power Consumption (Typical)
- 9 watt
- Power Consumption Stand by
- 0.5 watt
- 0.3 watt
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Shipping Width
- 43.4 cm
- Shipping Depth
- 7.6 cm
- Shipping Height
- 31 cm
- Shipping Weight
- 3.1 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 90%
