A stunning addition to any desk with its gorgeous ultra-slim 24" Full HD IPS display, the ASUS VZ249HE delivers vibrant colors with 178° viewing angle over HDMI/VGA. Built-in ASUS Eye Care technology actively reduces eye strain for prolonged viewing, while the frameless design delivers panoramic viewing immersion for multi-display setups.
Ultra-slim profile
VZ249HE takes up very little desktop space and fits well in any setting. -
Perfect for multi-display setups
Whether you're playing games, watching a movie, or getting some work done, VZ249HE's frameless design means two or three monitor setups are virtually seamless, giving you a panoramic display for an even greater degree of immersion. -
Ultra-low Blue Light monitor
The ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. -
Flicker-Free technology
It's time to say goodbye to those tired, strained eyes. VZ249HE features ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos. -
Wide 178° viewing angles
VZ249HE has an advanced high-performance IPS panel that provides an astonishing 80,000,000:1 contrast ratio and wide 178°viewing angles. This LED-backlit display covers the entire sRGB color space - ensuring extremely accurate color reproduction for professional-grade photo and video editing, or for home entertainment.
- ASUS VZ249HE - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/388968
- Energy Class
- Class D
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 13 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54 cm x 21.1 cm x 39.1 cm
- 2.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ERP, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 33 kWh
- Diagonal Size
- 24"
- Viewable Size
- 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Ultra Slim Design, HDCP, frameless, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Wide Viewing Angle, Colour Temperature Selection, 72% NTSC colour gamut
- Black
- 54 cm x 21.1 cm x 39.1 cm - with stand
- 2.9 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- Cables Included
- 1 x VGA cable
- Input Voltage
- 13 W
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 14.75 Watt
- Power Consumption Stand by
- 0.2 Watt
- 0.2 Watt
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 54 cm - depth: 3.7 cm - height: 32.3 cm , With stand - width: 54 cm - depth: 21.1 cm - height: 39.1 cm - weight: 2.9 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
