Delicate touches make a monitor truly great, VS229HA Full HD LED monitor, with 80000000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Superior image quality meets classic elegant design
Delicate touches make a monitor truly great. VS229HA Full HD LED monitor, embedded the wide-viewing-angle panel with 80000000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability. -
80000000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD with HDMI
Enter a spectacular world of colors with Full HD 1080p (1920 x 1080) support and HDMI port. -
178-degree ultra wide viewing angle
VS229HA adopts 178-degree (H)/178-degree (V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. -
Aspect control function
Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
- ASUS VS229HA - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 26.4 kWh
- Power Consumption (On mode)
- 18.1 W
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.41 cm x 20.063 cm x 38.722 cm
- 3.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, J-MOSS, ErP Ready, China Energy Label Level 1, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 26.4 kWh
- Diagonal Size
- 21.5"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature, aspect control
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Slim Design, 72% NTSC colour gamut
- Black
- 51.41 cm x 20.063 cm x 38.722 cm - with stand
- 3.5 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- 18.1 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 51.41 cm - depth: 4.84 cm - height: 31.518 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
