Get more flexibility when placing the USB-N14 adapter with the bundled USB extension cable. Greater freedom of placement means better reception, as it allows you to fine-tune positioning for the best signal available.
With the detachable high-gain antenna you get the option to greatly increase your signal coverage up to 10x more extensive than wireless-g adapters. Detachable design means you can connect and disconnect antennas at will, and even upgrade them in future if needed.
Advanced N speed
802.11n Wi-Fi offers the connection speeds you need to enjoy smooth HD streaming, online multiplayer gaming, downloading, and much more. -
Adjustable cable enhances reception
Get more flexibility when placing the USB-N14 adapter with the bundled USB extension cable. Greater freedom of placement means better reception, as it allows you to fine-tune positioning for the best signal available. -
External high-gain antenna supports up to 10x signal coverage
With the detachable high-gain antenna you get the option to greatly increase your signal coverage up to 10x more extensive than wireless-g adapters. Detachable design means you can connect and disconnect antennas at will, and even upgrade them in future if needed. -
One push setup
Simply setup a connection between your router and devices with two button presses thanks to auto detection and network integration. No manual settings input required, and security is assured thanks to strong encryption.
- ASUS USB-N14 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 5.5 cm x 9 cm x 1.1 cm
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Linux Kernel 2.6, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 300 Mbps
- Line Coding Format
- CCK, 64 QAM, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz
- WPS
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- Cables Included
- 1 x USB extension cable (external)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- OS Required
- 5.5 cm
- 9 cm
- 1.1 cm
