The USB-N10 is specially-designed to be compact and durable to safely and securely stay plugged into a notebook PC even inside a slim carrying case. The ASUS USB-N10 NANO provides a better wireless performance for your PC than legacy wireless 802.11g technology. It uses best-in-class antenna, MIFA, to perform consistent HD quality data streaming and to extend wireless receiving range. Not only does 802.11n offer you sufficient bandwidth and range, it's also backwards compatible with 11g and 11b networks.
Travel-friendly design
The USB-N10 is specially-designed to be compact and durable to safely and securely stay plugged into a notebook PC even inside a slim carrying case. -
Software AP wireless connection sharing
The built-in software AP function lets you easily share an Internet signal wirelessly to other PCs and devices. Also, manage individual connection privileges to optimize the wireless network. -
EZ N excellent connection
- ASUS USB-N10 NANO - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.49 cm x 1.74 cm x 0.71 cm
- 2 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple OS X 10.8 Mountain Lion
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 150 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz
- Access Point operational mode, WPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- C-Tick, IC, FCC, NCC
- Software Included
- Drivers & Utilities
- OS Required
- 1.49 cm
- 1.74 cm
- 0.71 cm
- 2 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.58 |
