Asus USB 3.1 2-PORT CARD - 2x USB 3.1 Ports (TypeA) PCIe
Quicklinx: B634WS00 Mfr#: USB 3.1 2-PORT CARD
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
ASUS brings you the world's first discrete USB 3.1 card. ASUS USB 3.1 card is the simple-to-fit PCI Express expansion card that works with any PCIe slot. It adds dual USB 3.1 ports to your ASUS motherboard for ultimate-speed transfers of up to 10 Gb/s - or twice as fast USB 3.0. The next-generation standard is completely backward-compatible with your existing gear, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 boost technology pushes real-world speeds faster than ever before.
ASUS USB 3.1 TYPE-A CARD - USB adapter - PCIe x4 - USB 3.1 x 2
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
Ports
USB 3.1 x 2
7.93 cm x 7.36 cm
USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
USB 1.1, USB 2.0, USB 3.0, xHCI, USB 3.1
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
USB adapter
Plug-in card
PCI Express x4
Ports
USB 3.1 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
2 x USB 3.1 (external)
Software Included
ASUS USB 3.1 Boost
7.93 cm
7.36 cm
