Aruba HP 2920-48G-POE+ Switch
Quicklinx: 8ZPZWS00 Mfr#: J9729A
The Aruba 2920 Switch Series provides security, scalability, and ease of use for enterprise edge, SMB and branch office networks. A powerful ProVision ASIC delivers low latency, more packet buffering, and adaptive power consumption. This Basic Layer 3 switch series supports modular stacking, 10GbE, RIP routing, PoE+, ACLs, sFlow, and IPv6. The Aruba 2920 Switch Series delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management and is ready for Software-defined Networking (SDN) with OpenFlow support.
  • Flexible and Scalable Access Layer Switches
    The Aruba 2920 Switch Series provides security, scalability, and ease of use for enterprise edge, SMB, and branch office networks.Cost-effective, pay-as-you-grow modular stacking support for up to four 10GBASE-T (or SFP+) links and upgradeable power supplies allow your network to quickly scale when needed.Robust Layer 3 feature set includes static and RIP routing, Access OSPF routing, ACLs, sFlow, IPv6, and requires no software licensing.Designed with a powerful ProVision ASIC and support for OpenFlow, the Aruba 2920 is ready for the software defined network with REST APIs and OpenFlow support.Optimized for the digital workplace with unified management tools such as Aruba ClearPass Policy Manager, Aruba Airwave and Aruba Central. Provides optimal configuration automatically when connected to Aruba access points for PoE priority, VLAN configuration, and rogue AP containment.
  • High Performance and Power at the Edge
    The Aruba 2920 Switch Series is designed with a powerful ProVision ASIC, providing low latency, increased packet buffering, and adaptive power consumption so the network can support the media-rich, bandwidth-intensive applications your business demands.Increase performance with selectable queue configurations and associated memory buffering that meet your network application requirements.With up to 740 W of internal PoE+ power, the Aruba 2920 Switch Series can easily scale to 1440 Watts with a simple connection to an external power supply (EPS) or redundant power supply (RPS).Plug and play stacking with automated failover enhances network resiliency and RPS support delivers power redundancy.Efficient 80 PLUS Silver Grade Power Supplies, Energy Efficient Ethernet, and LLDP-MED conserve energy resources. Removable power supplies reduce downtime during upgrades and servicing.
  • Security and Quality of Service (QoS)You Can Rely on
    The Aruba 2920 Switch Series includes security and quality of services features to build a network that meets ever-changing corporate policies and compliances and help protect your data from both inside and outside attacks.Flexible authentication options include standards based security protocols such as 802.1X, and MAC and Web for greater, policy-driven application security.Powerful, multilevel-access security controls include source-port filtering, RADIUS/TACACS+, SSL, Port Security, and MAC address lockout.Tunneled node to transport network traffic on a per-port basis to Aruba controller with authentication and network policies applied and enforced at the controller.
  • Simplify with Integrated Wired/Wireless Management
    The Aruba 2920 Switch Series supports Aruba ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports Aruba Airwave to provide common platform for Zero-Touch Provisioning management, and monitoring for wired and wireless network devices.Cloud-based management supported by Aruba Central.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.Out-of-band Ethernet management port keeps management traffic segmented from your network data traffic.
HPE Aruba 2920-48G-PoE+ - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Throughput: 130.9 Mpps , Switching capacity: 176 Gbps
IPv4 routing table entries: 2048 , IPv6 routing table entries: 256
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
RIP, RIP-2, static IP routing, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SMON, SSH, SSH-2, CLI
Flow control, DHCP support, BOOTP support, ARP support, trunking, VLAN support, IPv6 support, half duplex mode, full duplex mode, SNTP support, sFlow, MSTP support, ACL support, QoS, RADIUS support, PoE+, STP Root Guard, UDLD, LLDP support, LACP, Energy Efficient Ethernet, CoS, GARP
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1v, IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
44.25 cm x 33.6 cm x 4.39 cm
5.7 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
RADIUS, PAP, CHAP, TACACS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
1 x ARM ARM1176: 625 MHz
RAM
512 MB SDRAM
Flash Memory
1 GB
48 x Gigabit LAN 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE+ - 30 W , 4 x SFP (mini-GBIC) - SFP , 1 x RJ-45 , 1 x micro-USB Type B , Management: 1 x USB USB - 4 pin USB Type A , 1 x management RJ-45
Expansion Slots
2 (total) / 2 (free) x Expansion Slot , 1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Provided
575 Watt
487 Watt
80 PLUS Certification
80 PLUS Silver
C-Tick, GOST, CISPR 24, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class A, FCC Part 15 B, ICES-003 Class A, RoHS, EN 60950-1, IEC 60825-1, EN 60825-1, IEC 60950-1 Second Edition, VCCI Class A
44.25 cm
33.6 cm
4.39 cm
5.7 kg
Limited warranty - lifetime
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
8ZPZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
8ZPZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
