Arlo Smart Home Security Camera x2
NO CORDS. NO WIRES. NO WORRIES
Quicklinx: B68MWS00 Mfr#: VMS3230-100EUS
Select:
  • Twin
Includes 2x cameras
From kids and pets to an empty home or after-hours business, you've got a lot to keep safe. Day or night, indoors or out, Arlo takes the wondering and worrying out of life with the world's only 100% wire-free indoor/outdoor home monitoring system. Security so simple - just place Arlo's weatherproof cameras wherever you need them without needing to find a power outlet. They are battery powered that last up to 6 months. Then use the free Arlo app anytime, anywhere to see crystal-clear live and recorded HD video. Arlo's motion sensors automatically send alerts to your phone when movement is detected, and records to your free private cloud storage to review anytime. Arlo is always ready to go when you are - add extra cameras to your system with the touch of a button.
  • Robust design
    Built to withstand the elements, this surveillance system is compliant with IP65 standards, ensuring it remains operational in temperatures ranging from -10°C to 50°C. Whether it's the scorching heat or freezing cold, your security won't be compromised.
  • Night vision capability
    Enhanced with night vision, the Arlo VMS3230 allows for round-the-clock monitoring. This feature ensures that even in complete darkness, you can still keep an eye on your property with clear, detailed images.
  • Wireless convenience
    Say goodbye to the hassle of cables with the Arlo VMS3230's wireless connectivity. Operating on a 2.4 GHz frequency band, this surveillance kit offers the flexibility to place your cameras wherever you need them most, without worrying about running network cables.
  • Effortless installation
    This system comes with everything you need for a quick setup, including magnetic mounts, mounting screws, and lithium batteries. The magnetic mounts allow for easy adjustment of the camera's viewing angle, ensuring optimal coverage.
  • Reliable video quality
    Capture every detail with the CMOS sensor cameras, which ensure high-quality video footage. Combined with H.264 compression, this system provides efficient video storage and streaming, making it easier to monitor your space without sacrificing video quality.
Arlo VMS3230 - video server + camera(s) - wireless (802.11n)
System
Video server + camera(s) - wireless - IEEE 802.11n - 2.4 GHz
Camera
2 cameras - outdoor - night vision
System
Network Interface
IEEE 802.11n
Wireless Frequency Band
2.4 GHz
Waterproof
Package Content
Power adapter, 4 magnetic mounts, 4 mounting screws, 8 lithium batteries (CR123), window decal
Network cable - 1 pcs.
Security DVR
Compression Format
H.264
Video Server
RAM
64 MB
Flash Memory
16 MB
LED indicator
Cameras
Quantity
2 cameras
Camera Type
Outdoor
Sensor
CMOS
Field of View
130°
Night Vision
Infrared Distance
7.5 m
White Balance
Auto
-10 °C
50 °C
IP65
Network Port
10/100Base-T
Internet of Things (IoT)
Communications Type
Product-to-product
Details
Video server: 21.6 cm x 16.5 cm x 5.72 cm - 113 g , Camera: 4.1 cm x 7.1 cm x 6.4 cm - 113 g
