Arlo Smart Home 3 HD Security Camera Kit - Wireless CCTV, Indoor / Outdoor with Night Vision
NO CORDS. NO WIRES. NO WORRIES
Quicklinx: B68NWS00 Mfr#: VMS3330-100EUS
Select:
  • Trio
Includes 3x cameras
No Cords. No Wires. No Worries
From kids and pets to an empty home or after-hours business, you've got a lot to keep safe. Day or night, indoors or out, Arlo takes the wondering and worrying out of life with the world's only 100% wire-free indoor/outdoor home monitoring system. Security so simple - just place Arlo's weatherproof cameras wherever you need them without needing to find a power outlet. They are battery powered that last up to 6 months. Then use the free Arlo app anytime, anywhere to see crystal-clear live and recorded HD video. Arlo's motion sensors automatically send alerts to your phone when movement is detected, and records to your free private cloud storage to review anytime. Arlo is always ready to go when you are - add extra cameras to your system with the touch of a button.
The Arlo camera is completely wireless, with HD smart home security camera you can get exactly the shot you need - inside or out. The Arlo camera is weatherproof and includes motion detection, night vision and apps. It can capture clips and send you alerts whether you’re at home or away for round-the-clock peace of mind.
  • Get higher detail with HD cameras
  • Patented 100 per cent wire-free design for easy placement anywhere
  • Night vision cameras work even in the dark
  • Motion activated cameras and real-time email or app notifications
  • Indoor/outdoor weatherproof cameras
  • Free apps to securely view live video while home or away
  • 100% Wire free - say goodbye to trailing cables and wiring hassles
  • Motion Alerts - receive push notifications and emails if anything moves
  • Night Vision - see what's happening even in the dark
  • Weatherproof - place Arlo anywhere, indoors or out
  • HD Quality - enjoy amazingly sharp 720p live video, and sve those important moments with free Cloud Storage
Motion Detection Made Easy
  • Arlo records and alerts only when motion is detected so no battery power ever goes wasted.
  • Optimal camera placement is 7 feet above the floor, aimed slightly down.
  • The better area for motion detection is 5 feet to 20 feet (1.5 to 6 metres) from camera position.
Watch Anywhere with iOS and Android Apps
  • Up to 1 GB secure cloud storage included
  • View four video streams at the same time
  • Create and schedule smart home rules
Simple, Easy Setup
  • Arlo IP cameras are 100 per cent wire-free and they instantly attach to a fully magnetic mount for simple setup.
Box Contains
  • Arlo Smart Home Base Station
  • Power Adapter
  • 3x HD Security Cameras
  • RJ45 Cable
  • 4x Magnetic Camera Mounts with Screws
  • 12x CR 123 Batteries
  • User Documentation
  • Robust outdoor design
    Designed to withstand the elements, the Arlo VMS3330 cameras are compliant with IP65 standards, ensuring protection against dust and water. This makes them suitable for outdoor surveillance, operating efficiently in temperatures ranging from -10°C to 50°C.
  • Enhanced night vision
    Equipped with advanced night vision capabilities, these cameras provide clear video footage even in the lowest light conditions. This feature ensures continuous security, capturing critical details when they matter most.
  • Wireless convenience
    The Arlo VMS3330 surveillance kit offers a wireless setup, utilizing a 2.4 GHz frequency band for connectivity. This eliminates the need for extensive wiring, making installation straightforward and flexible for various locations.
  • Efficient video compression
    With H.264 compression format, the video server optimizes bandwidth and storage use. This technology ensures high-quality video recording while minimizing the required storage space, making it an efficient solution for your surveillance needs.
Arlo VMS3330 - video server + camera(s) - wireless
System
Video server + camera(s) - wireless - 2.4 GHz
Camera
3 cameras - outdoor - night vision
System
Wireless Frequency Band
2.4 GHz
Package Content
Power adapter, 4 magnetic mounts, 4 mounting screws, window decal, 12 lithium batteries (CR123)
Network cable - 1 pcs.
Security DVR
Compression Format
H.264
Video Server
RAM
64 MB
Flash Memory
16 MB
LED indicator
Cameras
Quantity
3 cameras
Camera Type
Outdoor
Sensor
CMOS
Field of View
130°
Night Vision
Infrared Distance
7.5 m
White Balance
Auto
-10 °C
50 °C
IP65
Network Port
10/100Base-T
Details
Video server: 21.6 cm x 16.5 cm x 5.72 cm - 113 g , Camera: 4.1 cm x 7.1 cm x 6.4 cm - 113 g
B68N C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
