With an Arlo system, you'll have everything you need to get started. Just connect the base station to your WiFi router, sync your cameras, fire up the free Arlo app, and you're done in minutes. Make sure to upgrade your service plan and add more cameras to make the most out of your system.
Enhanced connectivity
The Arlo Pro Base Station features multiple ports including RJ-45 and USB x 2, ensuring versatile connectivity options for a seamless integration into your home security setup -
Reliable power supply
Comes equipped with an external power adapter, providing a consistent and reliable power source to keep the video server operational without interruptions
