Arlo Pro 4 Spotlight Camera - White
Quicklinx: GF12WS00 Mfr#: VMC4050P-100EUS
Connect and control with your favourite smart assistant.
Works with Alexa, Apple Homekit and Google Assistant (Works with Apple Homekit when paired with an Arlo base station.)
Connect Direct to WIFI
No base station required - simply connect to your 2.4Ghz wifi network for the camera to work.
160° Field of View
Focus on the most vulnerable parts of your property with wide-angle 160-degree viewing.
2K-video with HDR
Superior image quality and 12x zoom with 2K HDR video that lets you capture important details with clarity.
Integrated Spotlight
A powerful spotlight lets you see important details even at night and helps deter intruders.
Built-in Siren
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
Colour Night Vision
Capture important information, even at night with vivid colour night vision.
Wire-free & Weather Resistant
100% wire-free and weather resistant for instant protection you can rely on.
3-month Arlo Smart trial included
With Arlo SMART security, the Pro 4 Spotlight camera lets you monitor and verify the security of you home. Enhanced detection features powered by artificial intelligence allows you to effectively distinguish people from pets - enabling you to choose what the camera keeps an eye on.
  • Convenient magnetic mount
    Quickly install your camera wherever you'd like and adjust it easily.
  • Long-lasting battery
    Get 6 months of battery life on one charge, and enjoy flexible, wire-free installation.
  • Fast charging
    The optional magnetic charging cable snaps into place for continuous power.
  • Respond to visitors, from anywhere
    Hear and speak to visitors clearly with 2-way audio right on your phone.
  • Quickly deter unwanted guests
    Trigger your siren automatically or manually from the Arlo app.
  • Weather-resistant for year-round security
    Certified to withstand heat, cold, rain, or sun.
  • Works seamlessly with your smart home
    Receive alerts and manage your home security using your favorite smart devices.
Arlo Pro 4 - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio
Yes: two-way audio capability, built-in microphone
Camera Mount Type
Wall mount
8.9 cm x 5.2 cm x 7.84 cm
316 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Motion Detection
Video Modes
720p, 1080p, 2K
Optical Sensor Type
1/3" - 4 MP
USB 2.0 IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi
Magnetic charging cable
Voltage
AC 100-240 V, DC 5 V
Auto tracking, High Dynamic Range (HDR), 160° field of view, built-in spotlight, 130-degree motion detection angle
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Audio Support
Camera Mount Type
Wall mount
Wired, wireless
8.9 cm
5.2 cm
7.84 cm
316 g
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Digital Video Format
H.264, H.265
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
720p, 1080p, 2K
Digital Zoom
12
Infrared LEDs
2
Image Sensor
4 MP 1/3"
Network Interface
Computer Interface
USB 2.0
Wall mount kit, screw kit, rechargeable battery, video monitoring decal
IC, FCC, RoHS, WERCS, EuP1275
White
Power Requirements
DC 5 V
AC 100-240 V (50/60 Hz)
1 (up to 6 months)
Limited warranty - 1 year
-20 °C
45 °C
GF12 Arlo Solar Panel Charger - Gen2 White - forArlo Go 2, Pro 3, Pro 4, Ultra, Floodlight In Stock £49.99
