Pro 4 Spotlight Camera
Connect and control with your favourite smart assistant.
Works with Alexa, Apple Homekit and Google Assistant (Works with Apple Homekit when paired with an Arlo base station.)
Connect Direct to WIFI
No base station required - simply connect to your 2.4Ghz wifi network for the camera to work.
160° Field of View
Focus on the most vulnerable parts of your property with wide-angle 160-degree viewing.
2K-video with HDR
Superior image quality and 12x zoom with 2K HDR video that lets you capture important details with clarity.
Integrated Spotlight
A powerful spotlight lets you see important details even at night and helps deter intruders.
Built-in Siren
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
Colour Night Vision
Capture important information, even at night with vivid colour night vision.
Wire-free & Weather Resistant
100% wire-free and weather resistant for instant protection you can rely on.
3-month Arlo Smart trial included
With Arlo SMART security, the Pro 4 Spotlight camera lets you monitor and verify the security of you home. Enhanced detection features powered by artificial intelligence allows you to effectively distinguish people from pets - enabling you to choose what the camera keeps an eye on.
Convenient magnetic mount
Quickly install your camera wherever you'd like and adjust it easily. -
Long-lasting battery
Get 6 months of battery life on one charge, and enjoy flexible, wire-free installation. -
Fast charging
The optional magnetic charging cable snaps into place for continuous power. -
Respond to visitors, from anywhere
Hear and speak to visitors clearly with 2-way audio right on your phone. -
Quickly deter unwanted guests
Trigger your siren automatically or manually from the Arlo app. -
Weather-resistant for year-round security
Certified to withstand heat, cold, rain, or sun. -
Works seamlessly with your smart home
Receive alerts and manage your home security using your favorite smart devices.
- Arlo Pro 4 - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Packaged Quantity
- 3 (specifications are for single item)
- Audio
- Yes: two-way audio capability, built-in microphone
- Camera Mount Type
- Wall mount
- 8.9 cm x 5.2 cm x 7.84 cm
- 316 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 720p, 1080p, 2K
- Optical Sensor Type
- 1/3" - 4 MP
- USB 2.0 IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi
- Cables Included
- Magnetic charging cable
- Voltage
- AC 100-240 V, DC 5 V
- Auto tracking, High Dynamic Range (HDR), 160° field of view, built-in spotlight, 130-degree motion detection angle
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Packaged Quantity
- Audio Support
- Camera Mount Type
- Wall mount
- Wired, wireless
- 8.9 cm
- 5.2 cm
- 7.84 cm
- 316 g
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Digital Video Format
- H.264, H.265
- Max Digital Video Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 720p, 1080p, 2K
- Digital Zoom
- 12
- Infrared LEDs
- 2
Image Sensor
- 4 MP 1/3"
- Network Interface
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi
- Computer Interface
- USB 2.0
- Included Accessories
- Wall mount kit, screw kit, rechargeable battery, video monitoring decal
- Cables Included
- IC, FCC, RoHS, WERCS, EuP1275
- White
- Power Requirements
- DC 5 V
- Power Device
- AC 100-240 V (50/60 Hz)
- Battery
- 1 (up to 6 months)
- Limited warranty - 1 year
- -20 °C
- 45 °C
