Arlo Go 2 is the most versatile security camera. Connect anywhere via Wi-Fi or a 4G SIM card to protect 100% of locations – with no wires needed.
- 3G/4G & Wi-Fi
- Video in 1080p
- Integrated Spotlight
- 130° Viewing Angle
- 100% Wire-Free
Versatile Security
Connect to Wi-Fi or a SIM card for flexible internet connectivity whatever the location. (Sim card not included)
Simple installation
100% wire-free the Arlo Go 2 is simple to install in a range of locations.
Defy the elements
Built to withstand rain, snow, cold and sun for reliable protection.
Smart Home Integration
Control your Go 2 camera with voice commands through leading Smart Home products.
Colour night vision
Integrated spotlight for colour night vision or black and white.
Flexible Power
Simply remove and charge indoors with the included Micro USB cable or pair with a solar panel (sold separately) for continual charging.
Siren Deterrent
Remotely trigger the built-in siren to scare off intruders or have it sound automatically.
Arlo Secure
Includes two year subscription to Arlo Secure.
What is included in Arlo Secure:
Cloud Video Quality: Up to 2K
Cloud Video History: Up to 30 days
Rich, Interactive Notifications
Person, Vehicle and Animal Detection
Package Detection
Cloud Activity Zones
Call a Friend
Theft Replacement
Specs
Resolution: 1080p
De-warping (Yes / No): Yes
HDR (Yes / No): No
Power Source: Battery
Horizontal Field of View: 130°
Light: Spotlight
Built-in Siren (Yes / No): Yes
Two-Way Audio (Yes / No): Yes
Microphone: Single
Noise Cancellation (Yes / No): No
Night Vision: Colour
Privacy Shield (Yes / No): No
Battery Life (Months): 4 months on 4G / 12-months on Wi-Fi
SmartHub Required (Yes / No / Optional): No
Local Storage: Micro SD in Camera
Security made mobile
Whether you have Wi-Fi or not, take your security anywhere with LTE, or Wi-Fi when you're closer to home. Set up is easier than ever with a truly wire-free setup so you can mount wherever you are. See more at night with the integrated spotlight and color night vision. Store and review videos locally with a microSD card slot. Watch and record video in 1080p high definition. -
Security without boundaries
With Arlo Go 2, stay connected even without Wi-Fi thanks to LTE so you can capture Crisp 1080p HD footage even in the most remote locations, or use Wi-Fi when it's available. -
See who's there, even at night
Capture the full picture in low light with color night vision, and use the integrated spotlight to illuminate wherever you are to identify critical details. -
Withstand the elements, year round
With all weather protection, the Arlo Go 2 can withstand anything Mother Nature throws at it - from rain, to snow, to freezing temperatures. -
2-way talk
Hear and speak to visitors with clear, 2-way audio. -
Ward off unwanted guests
Manually or automatically trigger the built-in siren to ward off guests.
- Arlo Go 2 - network surveillance camera
- Network surveillance camera - fixed - weatherproof
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 6.42 cm x 12 cm x 8.6 cm
- 490 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- LTE, Wi-Fi, 4G
- Intelligent Assistant
- Google Assistant, Alexa
- E-mail alerts, Push Notification, Smartphone Monitoring, built-in siren, cloud recording, Colour Night Vision, motion detection, sound detection, built-in spotlight, GPS module
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Audio Support
- Wireless
- 6.42 cm
- 12 cm
- 8.6 cm
- 490 g
Camera
- Colour - Day&Night - fixed - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 12
- Infrared LEDs
- Infrared Distance
- 7.62 m
- Digital Video Capture Resolution
- 1920 x 1080
- Network Interface
- LTE, Wi-Fi, 4G
- Supported Memory Cards
- microSD Card
- Included Accessories
- Screws, magnetic charging cable
- IP65
- Battery
- 1 3660 mAh
- Software Included
- Arlo Secure (3-months trial)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Supported Host Device Platform
- iOS, Android
- Limited warranty - 1 year , Subscription - 2 years
- -20 °C
- 45 °C
